Lockable DC Power Plug for Up Extreme Power Jack
All,
we are looking for a suitable **LOCKABLE **DC power plug for the new DC power jack on the Up Extreme.
According to the data sheets it should be 5.5mm x 2.5mm with M8x0,75 lock nut. However, it seems to be not a very common type of connector for lockable plugs.
The original Up Extreme power supply (EP-PS19V342A65W) seems to have an appropriate lockable plug. However, we rely on our own power supply with a different voltage level.
If someone knows a suitable lockable plug solution and could share any component information, it would be highly appreciated.
Thanks a lot in advance,
waldiman
We select a common DC lockable connector for UP Xtreme. If you could not find it in the market, please contact shop@up-board.org. We can sell it. It will be something like https://i.imgur.com/Gdi0j4g.png
I was also looking for a similar connector and hence by seeing this post, I contacted shop@up-board.org but got the reply that they can't provide such a connector and asked me to put a query on the community. Can you help us where we can purchase it or part number or link from where I could purchase?
We have successfully used the Switchcraft 761K reference that can be bought from usual suspects (Farnell, Digikey, Mouser, RSComponents...).
Hi @waldiman , now Up-shop is providing DC power plug on their store. Go check it out here:
https://up-shop.org/dc-cable-upxtreme.html -
Hi this DC power plug is not fitting into the board. Both board and plug has male connection.
@Aling can you share us the details from where we can purchase the power plug for UPXtreme, I don't want to use the AC adapter, I want to give the power through a battery.
as rreignier suggested the Switchcraft 761K works fine, you can find it on mouser or other shops and we will probably include in our shop soon too: https://eu.mouser.com/ProductDetail/Switchcraft/761K?qs=tCUFd3%2B19IMfpexPJCg8YQ==
