Will the Up Squared work for my application? PCI 9052 IO Bus
Hey All,
I have an application where I am connecting a proprietary card over PCI-104 to a PCI 9052 chip which converts our signals when this has a PCIe X16 connector which I use on my PC on my desktop. The PC I am currently using is x86_64 architecture running Windows 10 and Ubuntu 18.04 kernel 5.0.0-32 generic. I have no issues with this card on this PC. The motherboard on my desktop PC only has PCIe X1 so I am using a StarTech PEX1PCI1 adapter and I am providing external 5V and 12V power (this also allows me to cycle power with a relay). I believe for this application if I use something like this: https://www.amazon.ca/Mini-Express-Extension-Adapter-Riser/dp/B01FVPITN8 I can bridge between the mPCIe and PCIe.
Note: I tried this with a RockPRO64 and I am having issues. The driver they have on their kernel is unable to detect this card. It is also causing a stack exception on bootup when the device is connected to the PCIe port which makes booting only work 2/10 times. I am currently working with the Dev to try and solve this but they have limited time and we have not been successful.
Was wondering what you guys think.
    DCleri Posts: 1,213 admin
    The UP Squared has an Intel 64bit CPU, similar to your Desktop, so it should work without issues, but the only way to be 100% sure is to actually try that.
