[SOLVED] How to FORMAT the MMCBLK0
I an trying to install an Ubuntu Image on the mmcblk0 of the Up2 board, but the build fails due to mmcblk0 is full. I had a previous Win10 installation on. But i am unable to format the mmcblk0 completely.
How can i do this?
Can you please help. its becoming an expensive paper weight.
Regards
Maybe you can try with a live distribution og GParted or Partition Manager and try to format all your partitions. In this way you definitely delete everything from your partitions and all your board should be empty. After that you can try to install again your new Ubuntu Image.
Silvano
Eng. Silvano Bertoldo, PhD
Hi @Proinsios ,
You could try to use Gparted as @Sil said.
Also, assuming your are using the Ubuntu ISO from a USB stick:
https://wiki.up-community.org/Ubuntu#Install_Ubuntu_for_UP.2C_UP2.2C_UP_Core_and_UP_Core_Plus
During installation process, in the "Installation type" section, you can select "Erase disk and install Ubuntu". There, you will get your disk complete clean by the installer.
- 63 Announcements & News
- 139 Product News - New Product/Product Change Notice/ End-of-life
- 112 Welcome Developers!
- 60 Unboxing & Project Sharing
- 114 Tech Updates
- 3.6K UP Products
- 119 UP 7000
- 25 UP Squared i12
- 24 UP Xtreme i12
- 14 UP Squared Pro 7000
- 24 UP Squared V2
- 65 UP 4000
- 23 UP Xtreme i11
- 59 UP Squared Pro
- 135 UP Xtreme
- 820 UP Squared
- 74 UP Core Plus
- 217 UP Core
- 40 UP AI Edge
