Crashes on Heavy-Duty graphic usage
PascalPascal New Member Posts: 9
Hey,
my up² runs the most recent ubilinux. If I start Kodi and start a movie (Full HD), after a random time the system resets itself. I first thought this might be a power-relatet problem, but voltage is stable an I never saw a current over 2 Amps...
I had the same problem using windows 10 until I installed the most recent Intel GPU driver.
Do you have any suggestions were to start? I'd really like to see this system work...
PS: Not unsing Kodi (running the server headless) it works smooth even 24/7.
  • Javier ArteagaJavier Arteaga Emutex Posts: 163 mod
    Hi Pascal,
    Could you send me the output of this troubleshooting script on your UP2 while running Kodi?
    https://wiki.up-community.org/File:Sysinfo.zip
  • koriwikoriwi New Member Posts: 2
    hi, i have the same problem.
    when watching netflix, after random time, my up² restarts.
    Temps are good.
    only happening when youtube or netflix is running for a longer time.
    idle is fine.
    will post script output later
  • 4ng3l4ng3l New Member Posts: 6
    I have just the same problem: after a while working on Kodi under Linux Mint 18.3 Cinnamon or running Batocera x64 it crashes and reboots... Will active cooling solve this? I would rather know it than waste my money!
    edited April 2018
    Please, anyone has notice some improvement after upgrading to active cooling?
    A week ago I upgraded to active cooling my UP Squared based on Pentium . I still have to perform several more tests, but it seems that active cooling improves performance quite fine and prevents that system to reboot randomly.
    Mine even reboots with a 120mm fan attached :/
    Moderators, pls.
    I don't want to RMA it
