Step by step access to i2c from UBUNTU 16.4
Kiko
New Member Posts: 1 ✭
I have installed UBUNTU, 4.4.0-2-upboard .
I can flip/flop GPIO devices, but trying to write to any of the /dev/i2c devices produces no output in the device.
Do I need to configure the device in some way prior to try to write in the device?
Do you have some complete small example working?
Thanks in advance
Thanks in advance
Use i2c-tools, ie. i2cget and i2cset, if you want to use I2C from the command-line, or libmraa/libsoc/Linux ioctl-calls, if you're trying to use I2C from your own code.
